1999 Cadillac Serious Problem
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=85285
Printed Date: March 25, 2026 at 1:45 AM
Topic: 1999 Cadillac Serious Problem
Posted By: hzemall
Subject: 1999 Cadillac Serious Problem
Date Posted: November 07, 2006 at 12:36 PM
Ok, we have this Eldorado convertible (made by Coach Works in FL and it's scarey !) We did a deck install and used a data module for the deck install.
NOW, after the car sits for awhile (and drives) the circuit for the keyless (and who knows what else) locks up and the keyless starts, also when this locks up the memory for the radio drops out.
NOW, when you come back to the car and hit the keyless button the chime in the data module goes off and dings for a few seconds but the keyless is dead.
To reset it, you have to manually pop the trunk, pull the Convience fuse and put it back in which triggers the factory alarm then the keyless fob will work and disarm and unlock the car. The we start all over again.
The other day one of my guys was working near the car and heard the chime start dinging and saw the P Antenna go up and come back down.
Help ? Thoughts ?:)
Tim Baillie
Installer/Designer/Fabricator
Certified Autosound & Security
Posted By: mauri197
Date Posted: November 07, 2006 at 3:12 PM
NEVER SEEN THIS PROBLEM BUT WHAT MODULE DID YOU USE EXACTLY
Posted By: lsondubz
Date Posted: November 11, 2006 at 9:11 AM
Try a new Class 2 module?
Posted By: master5
Date Posted: November 11, 2006 at 12:38 PM
Some of these caddis have stumped me also, and I have pretty much seen everything. What I would reccomend is to plug the stock deck back in and undo anything else done to accomodate the new deck, and see if everything works normally again. If not, we can take it from there.
If so, I would strongly consider leaving the stock deck wired up, but extend the critical wires (power, data etc.) and relocate the factory deck to the trunk. Run wires from the speakers to the new deck and this way you have "fooled" the vehicle into not even knowing you swapped the deck out. Keep in mind if it's a bose system (99%) sure it is, you will need to swap speakers, or depending on how many speakers are in this system to re configure the ohms load to a minimum of 4 ohms per channel, if adding an amp you'll be ok @ 2 ohms per channel.
I had a situation once with a 96 seville (w/bose) that had serious current draw problems after doing a simple deck swap/ amp bypass. I was able to get that under control after several days BUT, the 99 system is different ( some similarities)so other systems in the vehicle are involved. The  96 was only a 4 speaker bose system (amazing all that insane wiring and modules for just 4 speakers) but I had to swap those out for 4ohm aftermarket speakers as well.
Now the other option might be you have a bad OR the wrong data module..these peices are fairly new to the market and might have bugs that need to be addressed. You didn't mention if this was a bose but I will assume it is. I have seen the diagram for that system along with the data lines and it's pretty hairy just for a sound system. I don't know what Mr. Goodwrench was on when doing this but best to leave it alone by relocating the factory deck IMO.
Good Luck
