Viper 791XV, remote programming
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=85381
Printed Date: May 15, 2026 at 1:32 PM
Topic: Viper 791XV, remote programming
Posted By: zenica
Subject: Viper 791XV, remote programming
Date Posted: November 09, 2006 at 9:49 AM
Hello all,
A few months back, you guys helped me install my alarm and it works greatwith one exception, I've lost the damn remote!! I've ordered a new one from DEIbut they tell me it has to be programmed. How do I do this and can I even do thisto a car that still has the alarm active???  If not, as I suspect, how do I disable the alarm?Can it be done with the key and the valet trigger? or some combination of???
Here is a link to my original thread...https://www.the12volt.com/installbay/forum_posts.asp?tid=61061&KW=zenica
Posted By: kgerry
Date Posted: November 09, 2006 at 10:34 AM
turn the key to ign and press the push/prgramming/valet button.... this will shut down the alarm...
as far as learning the new remote, open the drivers door, turn the key to ign, press the programming switch once then press and hold it in... the LED should flash once, then press button 1 on the new remote, then press it again... the LED shouldflash confirmation and the horn/siren will chirp to confirm....
Kevin Gerry
MECP First Class Installer
Owner/Installer
Classic Car Audio
since 1979
Posted By: master5
Date Posted: November 09, 2006 at 11:19 AM
Close...
Try this
Open door, turn key on,.....press the valet/override switch once, then once more and hold it.
you will hear one chirp.  Press a button on the remote. you will hear a conf. chirp.  let off valet switch and turn key off. Should work.
Posted By: Mike M2
Date Posted: November 09, 2006 at 3:22 PM
Follow the sequence above 4 times in a row and it will delete the transmitter you lost....
Mike M2
Tech Manager
CS Dealer Services
Posted By: jimmyjacksti
Date Posted: November 09, 2006 at 5:23 PM
Or you could press the valet button 11 times hold on 12 and press new remote this will delete all transmiters. Providing you door triggers operate properly...Then learn new remote press one time then press and hold, siren wil chirp press button one on remote and siren will long chirp new remote programed turn ign on then off exit prog mode... Learned...
Jimmy Jack
Posted By: zenica
Date Posted: November 09, 2006 at 9:43 PM
Thanks,this helps a lot...
No one said anything but I am guessing it can be done while the alarm is going off?
I noticed that after 3 times of going off after I left the door opened, it ignored that zone
and shut up.
Posted By: zenica
Date Posted: November 10, 2006 at 5:06 PM
Well, I tried the above and nothing...
The alarm continues to go off so long as the key is in the ignition and
it ignores the valet button....
Any ideas?
Posted By: JWorm
Date Posted: November 11, 2006 at 12:28 PM
Any ideas?
Did you turn the key on?
