2006 dodge ram remote start problems
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=85460
Printed Date: May 16, 2026 at 4:22 AM
Topic: 2006 dodge ram remote start problems
Posted By: 2 ridgebacks
Subject: 2006 dodge ram remote start problems
Date Posted: November 10, 2006 at 11:21 PM
hello i have a 2006 megacab i have a autostart 1812fm remote starter and a pku ch2x bypass the bypass has a data output to the second start wire but what do i do with the ignition and start wires from the remote starter also do i need to use a relay and resistor on a second start wire from the remote starter thanks for any help
Date Posted: November 10, 2006 at 11:46 PM
i think its just the second start wire i need info about thanks
Posted By: qdaddy
Date Posted: November 11, 2006 at 1:45 AM
negative trigger 180 ohm resistor use a relay
accs 610 resistor / relay
both outputs wire to the PURPLE / brown         posted_image
Date Posted: November 11, 2006 at 9:11 AM
the wire from the bypass that goes to the PURPLE / brown mux wire is this the one that neds the relay or another one
Date Posted: November 11, 2006 at 9:36 AM
please help to wire the relays im doing it today before it gets any colder thanks
