1997 Honda Prelude Factory Keyless
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=85666
Printed Date: April 18, 2026 at 7:28 AM
Topic: 1997 Honda Prelude Factory Keyless
Posted By: damagezwk
Subject: 1997 Honda Prelude Factory Keyless
Date Posted: November 15, 2006 at 12:33 PM
Does anyone know where the factory keyless module is located?  i think mine got unhooked or something when the people that had it before me put a alarm on it... they took the alarm off of it before i bought it and now the keyless doesnt work... any help would be appreciated.. its a 1997 honda prelude s model...
"Vtec Keep Left, Slow Traffic Keep Right"
Posted By: thepencil
Date Posted: November 15, 2006 at 12:46 PM
DIRECTWIRE™ WIRING INFORMATION - HONDA / PRELUDE / 1997 / Keyless Entry
12volts white    +   ignition harness
Starter BLACK/ white    +   ignition harness
Ignition BLACK / YELLOW    +   ignition harness
Power Lock BLACK/ white    -
Notes: located in the passengers kick at the multiplex control unit in a blue 14 pin connector. May also be in a gray 2 pin connector taped to another harness with blue tape above the driver kick panel.
Power Unlock blue/orange    -
Lock Motor WHITE/ red      bottom of fuse box
Unlock Motor lt.GREEN/ red      bottom of fuse box
Parking Lights+ RED / black
Notes: located in a white plug just behind the cruise control switch.
Parking Lights-
Hazards
Turn Signal(L)
Turn Signal(R)
Door Trigger WHITE/ black    -   bottom of fuse box
Dome Supervision comes on with unlock
Trunk/Hatch Release
Power Sliding Door
Factory Alarm Arm
Factory Alarm Disarm
Disarm No Unlock blue    -   in drivers door
Horn Trigger blu/rd or lt grn/blu    -   steering column
Memory Seat 1
Memory Seat 2
Memory Seat 3
Interface Module: Category:
Immobilizer Bypass Required:
Yes Type:
Transponder
Part #: 555DW
Alternate Part1 #: 556UW
Alternate Part2 #: DesignTech 20402
Alternate Part3 #: DesignTech 29402
Notes:
Smart Starter Kill Relays: Not Available
Directed Electronics assumes no responsibility with regards to the accuracy or currency of this information. Proper installation in every case is and remains the responsibility of the installer. DEI assumes no liability or responsibility resulting from improper installation, even in reliance upon this information.
Be careful whose advice you buy, but be patient with those who supply it.posted_image
Date Posted: November 17, 2006 at 5:52 PM
so are you saying that its the multiplex unit? cause i dont see anything about the FACTORY keyless module???
Posted By: KarTuneMan
Date Posted: November 18, 2006 at 4:51 AM
It's "built in " to the fuse box. UP HIGH you'll find the plug you need with the lock wires in it. The plug is grey.
