2002 dodge ram remote starter
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=8578
Printed Date: March 30, 2026 at 5:29 AM
Topic: 2002 dodge ram remote starter
Posted By: tonythompson
Subject: 2002 dodge ram remote starter
Date Posted: January 25, 2003 at 5:04 PM
im trying to hook up a bulldog  rs114 to my 2002 dodge ram,can not get door locks to work anyone got any ideas i have bought there dual relay harness but the way they say to wire it does not work what about resistors do i need to get some?
Posted By: jrilla
Date Posted: January 25, 2003 at 5:12 PM
Lock requires a negative trigger thru a 820 ohm resistor. Unlock requires a negative trigger thru a 330 ohm resistor. MUST use relays
J Rilla
Owner/Installer
Posted By: auex
Date Posted: January 25, 2003 at 6:32 PM
Wire color is WHITE/ Green and is located on the drivers side at the white plug under the main junction box for the wires going through the firewall.  If it is a diesel (old body style) then refer to the 2001 info.
Certified Security Specialist
I promise to be good.
Tell Darwin I sent you.
Posted By: Chris Luongo
Date Posted: January 26, 2003 at 4:10 PM
And don't forget to check for a factory alarm.  If you have one, you should instead use the GREEN/ orange arm/disarm wire; this does the locks too.
