Remote starter in 99 Accent not heating
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=8595
Printed Date: March 30, 2026 at 10:26 AM
Topic: Remote starter in 99 Accent not heating
Posted By: mistr_e
Subject: Remote starter in 99 Accent not heating
Date Posted: January 25, 2003 at 11:55 PM
I've owned my Accent GSI for 3 years now and just love it. haven't had any problems and wondered if maybe I lucked out given all the other complaints I hear about them. Recently though I had a basic ProStart car starter installed and when I use the remote the car starts but the heater doesn't come on. It's something I'd rather fix myself and am learning about how they are hooked up but I'm wondering if anyone has any suggestions of where to start. I'm also wondering if power locks on the remote are easy to do, but one project at a time.
Thanks a lot,
a keep up the great web site
Posted By: ViperATC5
Date Posted: January 26, 2003 at 7:52 AM
it appears that one of the accessory wires in the car is not being powered up by the remote start
|              12V|red or blk/blu      |+  |ignition harness            |
|          STARTER|BLACK / YELLOW        |+  |ignition harness            |
|         IGNITION|BLACK/ white         |+  |ignition harness            |
|        ACCESSORY|blue/white          |+  |ignition harness            |
| SECOND ACCESSORY|blue                |+  |ignition harness            |
|       POWER LOCK|add actuator        |   |in drivers door             |
|     POWER UNLOCK|same                |   |                            |
| PARKING LIGHTS +|GREEN / WHITE         |   |wht plug left st. col       |
| PARKING LIGHTS -|RED / black           |   |headlight switch            |
|       HEADLIGHTS|blue/black          |-  |headlight switch            |
|     DOOR TRIGGER|purple              |-  |blu plug left st. col       |
| DOME SUPERVISION|use door trigger    |   |                            |
|  TRUNK/HATCH PIN|BROWN / black         |-  |at light or pin switch      |
|       TACHOMETER|brn/red or blu/yel  |   |ignition coils              |
|      SPEED SENSE|yellow/white        |   |diag plug, under dr dash    |
|       BRAKE WIRE|green               |+  |brake pedal switch          |
|     HORN TRIGGER|BLACK/ white         |-  |steering column             |
|           WIPERS|RED / yellow          |-  |steering column             |
|  LF WINDOW UP/DN|blue - blk/yel      |A  |window switch               |
|  RF WINDOW UP/DN|blu/red - blk/wht   |A  |window switch
