07 Toyota Camry CE Manual
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=86061
Printed Date: May 19, 2026 at 8:35 PM
Topic: 07 Toyota Camry CE Manual
Posted By: ziggyb222
Subject: 07 Toyota Camry CE Manual
Date Posted: November 23, 2006 at 9:22 AM
Going to do a remote start in this car. Anyone with any experience on the manual trans car?? Anything out of the ordinary? Looks like all have the transponder.. Any help would be great... Thanks
Posted By: Mike M2
Date Posted: November 23, 2006 at 10:43 AM
Not all have the transponder. Look for the security light flashing on the cluster.
Mike M2
Tech Manager
CS Dealer Services
Posted By: Chris Luongo
Date Posted: November 23, 2006 at 11:11 AM
--I haven't seen an '07 Camry without a transponder yet, not even the CE.
--There is no factory alarm, and no power trunk release, on the CE.
When reading wiring diagrams, ignore anything that mentions trunk release or alarm arm/disarm, because you have neither.
--There are safe and unsafe methods of doing remote start on manual transmissions; use the search feature here for details.
The moderators of this forum will delete or lock out posts looking for help using the unsafe methods.
There are remote start units available that are specifically designed for manual transmissions. The safety features will make the unit less convenient to operate, but then again, people are far less likely to get hurt.
Posted By: Mike M2
Date Posted: November 23, 2006 at 12:11 PM
Once again Chris, you are correct. I thought i remember doing a few without immobilizers, so i did a check at www.toyota.com and sure enough it is standard on all Camrys. I could have sworn i've seen some without...
Mike M2
Tech Manager
CS Dealer Services
Date Posted: November 23, 2006 at 9:22 PM
Yes i realize the safety aspects of the remote start in a man. trans. And I have the model specifically designed for the man. trans.. What I was looking for was input from others who might have done the man Camry.. And thanks for your input..it is great..
