Install prestige 996 in a 94 Q 45!
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=8645
Printed Date: March 31, 2026 at 12:00 AM
Topic: Install prestige 996 in a 94 Q 45!
Posted By: raydog666
Subject: Install prestige 996 in a 94 Q 45!
Date Posted: January 27, 2003 at 8:05 AM
If possible, can someone help me with the wiring scem. for mycar?
Posted By: Velocity Motors
Date Posted: January 27, 2003 at 8:17 AM
|              12V|WHITE/ black         |+  |ignition harness            |
|          STARTER|BLACK/ red           |+  |ignition harness            |
|         IGNITION|BLACK/ white         |+  |ignition harness            |
|  SECOND IGNITION|                    |   |                            |
|        ACCESSORY|blue                |+  |ignition harness            |
|       POWER LOCK|orange              |-  |in drivers door             |
|     POWER UNLOCK|lt. blue *1         |-  |in drivers door             |
| PARKING LIGHTS +|RED / yellow          |   |dimmer switch               |
| PARKING LIGHTS -|RED / yellow          |   |steering column             |
|       HEADLIGHTS|RED / white, RED / black|-  |steering column             |
|     DOOR TRIGGER|GREEN/ YELLOW        |-  |body control module *2      |
|  TRUNK/HATCH PIN|RED / white           |-  |BCM *2                      |
|         HOOD PIN|BLACK/ pink          |-  |BCM *2                      |
|TRNK/HTCH RELEASE|purple              |-  |trunk release sw. *3        |
|  FCTRY ALARM ARM|arms with lock      |   |                            |
|FCTRY ALRM DISARM|disarms with unlock |   |                            |
|       TACHOMETER|BLACK/ green         |   |ECM in the pass kick        |
|       BRAKE WIRE|RED / green           |+  |brake switch                |
|     HORN TRIGGER|WHITE/ green         |-  |steering column             |
|           WIPERS|lt. GREEN/ red       |-  |wiper switch                |
|  LF WINDOW UP/DN|blue - yellow       |A  |in L.F. door                |
|  RF WINDOW UP/DN|blue - yellow       |A  |in R.F. door                |
|  LR WINDOW UP/DN|blue - yellow       |A  |in L.R. door                |
|  RR WINDOW UP/DN|blue - yellow       |A  |in R.R. door                |
Notes:
*1 Unlock requires a double pulse.  *2 The body control module (BCM) is located behind the left side of the dash, near the firewall.  *3 Can also be found at the trunk cancel switch.
