97 ford explorer remote start, 555F
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=86519
Printed Date: April 04, 2026 at 4:07 AM
Topic: 97 ford explorer remote start, 555F
Posted By: pitoaudiovisual
Subject: 97 ford explorer remote start, 555F
Date Posted: November 10, 2006 at 7:33 AM
just wanted to know if my do a remote start for a 97-98 ford explorer does it need a bypass somebody told me yes a 555f but in the paper work it doesn't have it... Thanx in advance..
------------- Confidence is the key to any project!!
Posted By: Hymer
Date Posted: November 10, 2006 at 8:40 AM
If it has a big key, then yes you need one... If it has a thinner key then no you don't 97 I dont think so.. On my wifes 98 I had to use the "bulb" style from DEI [forgot the p/n on it] But that worked great!
------------- Tire Proz Stillwater Mn
High End Restyling and Comlete Repair
Posted By: qdaddy
Date Posted: November 11, 2006 at 2:33 AM
as stated above fat key needs to be bypassed or look for a theft light on light cluster 556u works best and easier if needed
Date Posted: December 01, 2006 at 11:07 PM
I had to install a remote start to a Ford Explorer and tried to use a 555F but the bypass never learned the key code can anyone tell me exactly how to program it cause I tried to do it . I used the two keys like the instructions say and I connected the red wire to constant and the blue to the remote start wire but the car would not start with the alarm. I turned the key till the security light turned off then I did it with the other key but nothing.It attempted to but was never successful. Do i have to put the chip anywhere in particular during this process. Any help is appreciated.. Thanx in advance.
Posted By: captainzab
Date Posted: December 01, 2006 at 11:16 PM
After the 2nd key, you know your suppose to place the pellet infront of the key cylinder then remote start.
I usually stick it as close to the key cylinder as i can for the first remote start attempt.
I can usually get the 555f to program on fords with first attempt.
------------- Note: You Always Dont Get What You Pay For.
Date Posted: December 01, 2006 at 11:23 PM
after the second key I stuck it where the key would go but nothing. Just wondering if during the programming if the pellet should be anywhere in particular or maybe just a bad 555F. Should the blue be grounded during this process or just the constant connected and the ground only when auto started.
Date Posted: December 01, 2006 at 11:26 PM
dont worry about the pellet during program of first 2 key.
blue wire needs to connect to status wire or your starter.
programming the 555 is the exact same a programming a new key to the ford.
Wat year explorer? a year that can use the 555f i hope.
Date Posted: December 01, 2006 at 11:33 PM
yes a 99 ford explorer
Posted By: kgerry
Date Posted: December 02, 2006 at 12:10 PM
yes, when learning the pellet i ground the status (blue) wire... then after it's learned you connect the status to the unit.... just like learning the 555C & 556C as well......
------------- Kevin Gerry
MECP First Class Installer
Owner/Installer
Classic Car Audio
since 1979
Date Posted: December 02, 2006 at 2:45 PM
ok so neither the pellet or the little black box need to be placed anywhere
Posted By: Chris Luongo
Date Posted: December 02, 2006 at 5:30 PM
Of course the Ford needs to see the pellet, or it can't possibly learn it.
1. First key on until security light goes out, remove key.
2. Second key on until security light goes out, remove key.
3. Position 555F pellet in front of or close to keyhole, and activate remote starter. Car should start and run successfully.
4. Hit the brake to kill the remote starter, wait a few seconds........hold the pellet to the keyhole, and try the remote start again....... if it works now, you've 100% programmed it right.
5. Find a position on the side of the key cylinder where the 555F will still work, attach it there permanently......... re-test......... re-assemble the car, and re-test again.
TIPS:
--The entire rest of the remote-start installation should be completed first.
The remote start should successfully work with one of your existing keys sitting in the ignition, in the off position.
If it doesn't, fix all your other problems first, before messing with the 555F.
--There is no reason to make any sort of temporary connections to the red or blue wires of the 555F. Right from the start, they should be properly connected to the remote starter according to the instructions.
--The pellet thing on the 555F is an incredibly stupid, time-wasting design. If you're a rookie, plan on a good 10-20 minutes fiddling around with a good location..........someplace that it works, but still allows the car to be re-assembled........ refer to step 5 above, and make sure you're in a good mood before you start.
Date Posted: December 02, 2006 at 10:50 PM
i just dont understand how the pellet learns the key signal .. I connecte the blue to - status of remote start and red is constant. The pellet i left hanging down and the black box was also hanging down so i just wondered if the pellet should be placed near the key or should the little black box should be placed anywhere. I did the status light but just wondering about the placement of the actually pellet and little black box during the programming of the 2 keys.. I followed the exact directions so just curious any help is appreciated..
Posted By: kgerry
Date Posted: December 03, 2006 at 3:00 PM
the pellet does not learn the key signal... the vehicle learns the pellet as a spare key.... which it obviously cant do if you do not have the pellet placed close to the transponder ring...i have lots of these 555F's in stock and still prefer to use a XK04.... much easier to use and more reliable..... ------------- Kevin Gerry
Owner/Installer
Classic Car Audio
since 1979
Posted By: Mike M2
Date Posted: December 03, 2006 at 6:40 PM
I much prefer the 556S over the 555F. The F can be a real pain to get the pellet positioned correctly after it has learned. The S learns the same way, yet uses a coil ring instead. Think of the F as a third key, it's really all it is beyond a relay to turn it on. It programs exactly the same way. Most of the problem doesn't stem from programming, but getting the factory coil to read the F pellet. Place the pellet directly next to the coil on the switch and hold it with your hand. Try the RS a couple times, moving the pellet to different positions to see if it will read. It has to be VERY close to work... ------------- Mike M2
Tech Manager
CS Dealer Services
