Remote Starter 2006 Scion TC
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=86686
Printed Date: May 02, 2026 at 10:36 AM
Topic: Remote Starter 2006 Scion TC
Posted By: kawizx902
Subject: Remote Starter 2006 Scion TC
Date Posted: December 05, 2006 at 8:49 PM
Hello i am trying to find the neutral saftey switch in a 2006 scion tc. My friend added a remote start on a nissan sentra and he tapped into the neutral safety switch on the transmisson. So no matter what if the shifter is in any gear it will not start. If its in neutral it will start. I am going to try putting one in a scion and i am unfamiliar with the location of the neutral safety switch. any help would be greatly appreciated. thanks
Posted By: KarTuneMan
Date Posted: December 06, 2006 at 8:57 AM
Manual trans, or auto? AND what are you installing? (brand and part #)
Date Posted: December 06, 2006 at 1:23 PM
it is a manual. i am not sure what unit i have many to choose it will be a dei. i found the switch now we will see if it works thanks
Posted By: Chris Luongo
Date Posted: December 06, 2006 at 5:14 PM
I was about to tell you that I don't think there's a neutral-safety switch on Toyota products..........but you found it?
Please post back with details. Where? And what polarity when the car is in neutral?
Date Posted: December 06, 2006 at 11:32 PM
well i thought i found it but no luck. i will be trying again over the weekend. i am thinking of adding two hood pin switches in side the car under the shifter where the shifter cable is. so if the shifter is in any gear it will trigger the switch and disable the remote starter. i have done this before and it work great
Posted By: ers1121
Date Posted: December 07, 2006 at 4:07 AM
Most manual transmission car sdo not have a neutral switch. The clutch switch is the safety.
------------- Ed
Posted By: Mike M2
Date Posted: December 07, 2006 at 7:02 AM
Here's a trick i've done for manuals and it's worked for me. I installed a shock sensor directly on the motor to disengage the starter if the motor jumps(which it will if in gear with the e brake on). You have to use a cheap sensor that will trigger easy, and one that has water resistance(like the old clear ones that were mounted on a SS strap). The most the car moves is an inch or so. Adjustment is critical tho...
------------- Mike M2
Tech Manager
CS Dealer Services
Date Posted: December 07, 2006 at 2:07 PM
