2000 Nissan Frontier
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=86738
Printed Date: April 22, 2026 at 4:07 AM
Topic: 2000 Nissan Frontier
Posted By: crhny77
Subject: 2000 Nissan Frontier
Date Posted: December 06, 2006 at 5:08 PM
I installed an Audiovox Remote start in this vehicle and the starter grinds quickly when the key is turned to the on position when it is in remote start mode. I have never had this happen. Does anyone know what this could be?
Posted By: CruisinS&S
Date Posted: December 06, 2006 at 7:26 PM
Yes in some of the Nissans' the acc. will back fire in to the starter wire. It's a quick fix Which Audiovox unit so I can further help?
Cruisin Security And Sounds
Posted By: KarTuneMan
Date Posted: December 06, 2006 at 10:11 PM
You need to isolate the starter wire....or break it with a relay
on a relay use your ground while running to pin 85  12 volts to pin 86. Cut the starter wire the key side goes to pin 30, the starter side to pin 87a.
