2002 olds aurora ignition switch
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=86837
Printed Date: May 05, 2026 at 3:34 PM
Topic: 2002 olds aurora ignition switch
Posted By: 16663
Subject: 2002 olds aurora ignition switch
Date Posted: December 08, 2006 at 7:02 AM
Does anyone out there know the easiest way to get to the ign. switch for remote starter install on this make and model?
Posted By: Chris Luongo
Date Posted: December 08, 2006 at 7:50 AM
Oh man, that's a lot of fun. I just did one of those cars a couple of weeks ago.
Well, to start with, it's really fast and easy to remove the center dash trim, radio, and climate control panel........that'll let a little more light in there.
The center dash panel is real wood. Don't pound on it too hard with your hand when reinstalling it, or you'll learn the hard way what happens to the wood.
Anyway, if you first take off the lower dash panel, and lay down on your back and look up there with a good light...........if you have a long, thin, hook-shaped to (or maybe a flat screwdriver), you can manipulate the little clips to get the plugs undone, and then you'll be able to pull all of the ignition wires down toward the driver's floor where you can work.
Since you won't be able to test the wires when they're unplugged, you'll have to work extra carefully. There are several orange wires there-----the ones that have constant power are obviously your constants.......the other one is accessory.
Again, you don't have to remove the radio, but it only takes a few minutes, and it does allow more light to get in there, so you can see what you're doing when you try to undo those little clips.
Posted By: KarTuneMan
Date Posted: December 08, 2006 at 9:00 AM
Pull the entire center console area.....much easier, plus you'll learn. It's an easy yank.
Posted By: 16663
Date Posted: December 08, 2006 at 12:26 PM
Thanks for the experienced info!!
