compustar wont program remote
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=86956
Printed Date: April 26, 2026 at 11:47 PM
Topic: compustar wont program remote
Posted By: rob_03
Subject: compustar wont program remote
Date Posted: December 10, 2006 at 4:38 AM
alarm: compustar 2wass
car: 2003 acura rsx base
i wired everything up right and checked over and over, i turn my ignition 5 times and the relay clicks once the second after i turn it the 5th time then clicks twice more a couple seconds later
i put in the battery and after like 20 seconds the pager beeps 3 times and it doenst work
any ideas ?
Posted By: rob_03
Date Posted: December 10, 2006 at 5:10 AM
also when the siren is connected to the brown wire and i take out the ground of the brain, the siren is not loud, when i put the siren in another +12v of the brain its loud
my pager flashes a little icon next to the battery meter, its a straight line with a upside down triangle on top with a lightning bolt above it
ive tried pressing the button after turning the key 5 times and it chirps but still has that bolt and doenst work
tried a new ground
only thing i dont have is the dei5551, do you think that is the problem?
Posted By: evois
Date Posted: December 10, 2006 at 3:30 PM
put the battery in the remote and turn the key 5x from ACC to ON, not LOCK to ON in a span of 7 seconds not 10 seconds, meaning really fast and after the 5th turn press the I or whatever button needs to be press in your remote.
Posted By: larkster
Date Posted: December 10, 2006 at 10:14 PM
antenna plugged in?
