autopage rs860lcd on a xb
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=87323
Printed Date: April 23, 2026 at 11:10 PM
Topic: autopage rs860lcd on a xb
Posted By: sik99ranger
Subject: autopage rs860lcd on a xb
Date Posted: December 16, 2006 at 10:03 PM
im installing a autopage 860 on my 06 scion xb and i was wondering about the pink wire in the 20 pin harrness that controles the 2 step unlock.  How do i wire it in and also how do i wire the door locks?  Thanks Rich
Posted By: Twelvoltz
Date Posted: December 21, 2006 at 9:04 PM
DIRECTWIRE™ WIRING INFORMATION - SCION / XB / 2006 / Keyless Entry
[PRINT THIS PAGE]
12volts      wht/blue (40A), wht/red (15A)       +       ignition harness
Starter      black       +       ignition harness
Ignition      black       +       ignition harness
Power Lock      blue/white       -       driver kick, 14 pin plug
Notes: Meter this wire while turning the key in the driver door key cylinder.
Power Unlock      yellow/black (double pulse)       -       driver kick, 14 pin plug
Can also use the passenger door key cylinder wire for unlock, which only requires a single pulse. It is blue/red (-) in the passenger kick in a 14 pin plug.
Lock Motor      blue/orange       5wi      driver kick, 9 pin plug
Unlock Motor      YELLOW /GREEN       5wi      driver kick, 9 pin plug
Parking Lights+      green       +       headlight switch
Notes: Also found at the top of the fuse box in a 13 pin plug.
Parking Lights-      N/A
Hazards      GREEN/ orange       -       hazard switch
Turn Signal(L)      GREEN/ black       +       top of fuse box, 13 pin plug
Turn Signal(R)      GREEN/ YELLOW       +       top of fuse box, 13 pin plug
Door Trigger      RED / white       -       top of fuse box, 9 pin plug
Dome Supervision      use door trigger wire
Trunk/Hatch Release      BROWN / yellow       -       driver kick, harness to rear
Notes: Meter this wire while opening the hatch from the handle on the rear hatch.
The hatch release motor wire is blue / YELLOW (+) in the driver kick, harness to rear.
Power Sliding Door      N/A
Factory Alarm Arm      N/A
Factory Alarm Disarm      N/A
Disarm No Unlock      N/A
Horn Trigger      WHITE/ red       -       horn switch
Memory Seat 1      N/A
Memory Seat 2      N/A
Memory Seat 3      N/A
Interface Module:      Category:
Immobilizer Bypass      Required:
No      Type:
N/A
Part #: N/A
Notes:
Smart Starter Kill Relays: Not Available
warning
Directed Electronics assumes no responsibility with regards to the accuracy or currency of this information. Proper installation in every case is and remains the responsibility of the installer. DEI assumes no liability or responsibility resulting from improper installation, even in reliance upon this information.
Wire a 5-wire setup to the unlock of the drivers door motor using the system's normal/first unlock wire as a trigger. Then use the standard unlock output to the power unlock in the passenger kick panel as listed above.
