02 civic door lock problem
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=87504
Printed Date: April 09, 2026 at 10:07 PM
Topic: 02 civic door lock problem
Posted By: mike08401
Subject: 02 civic door lock problem
Date Posted: December 19, 2006 at 5:05 PM
i just installed a combo alarm and starter crimestopper cs2011 to my uncle 02 Honda civic ...and according to instruction book I have diode connect in between alarm unit wire and the car door lock wire but it will not work either I try any side of diode I follow manual book and this forum instruction but it won't work when diode connected and just work without it...Can any expert please help me B/c I'm afraid It could harm the brain of car or brain of alarm unit
Thank You
Posted By: advanced
Date Posted: December 19, 2006 at 5:54 PM
It is not necessary to install any diodes for door lock or unlock. They are straight negative trigger.
Good Enough Isn't!
Posted By: mobilecustoms
POWER LOCK WHITE/ BLUE (TYPE B)   IN GRAY PLUG, ABOVE DRIVERS KICK PANEL
POWER UNLOCK WHITE/ GREEN (TYPE B)   IN GRAY PLUG, ABOVE DRIVERS KICK PANEL
if your unit has straight neg lock outputs hook directly to it no diodes needed
Date Posted: December 20, 2006 at 1:13 AM
Thanks for respond...I did hooked it up and it works fine. Just not so sure if it Ok to leave that way...
Thanks again and happy holidays to allposted_image
Date Posted: December 20, 2006 at 8:15 AM
its fine to leave it that way
