Valet 562T, 02 Avalanche
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=87513
Printed Date: April 09, 2026 at 9:01 AM
Topic: Valet 562T, 02 Avalanche
Posted By: cehurley73
Subject: Valet 562T, 02 Avalanche
Date Posted: December 19, 2006 at 8:18 PM
Does anyone out there have the specifics for wiring a Valet 562T in a 2002 Avalanche? I'm wanting to hook up everything, including the defroster, and coming up emply handed for a complete list of the wire colors/locations for all the wires on this remote start. Also would like to know of any relays or diodes I will need, as I want to keep the factory unlock the same, where one push of the unlock only unlocks the drivers door, and two presses of the button unlock all of them. I received the remote start as a gift with a bypass for passkey II. All the sites I've found are either incomplete (bulldog is close, but missing some of the wires I need), or I can only get the vehicle specific chart if I bought my unit from their company. Can anyone end my frustrations?
Posted By: KarTuneMan
Date Posted: December 20, 2006 at 8:17 AM
Trigger the rear defrost at the defogger switch....white wire, it's a NEG(-) pulse.
Date Posted: December 21, 2006 at 3:24 PM
thank you!
Date Posted: December 21, 2006 at 3:31 PM
do I need a relay or diode to trigger this wire, or just tap a direct connection?
Posted By: mobilecustoms
Date Posted: December 21, 2006 at 3:47 PM
you can directly tap the wire in the car with the valet defrost wire.
Date Posted: December 21, 2006 at 7:21 PM
Thank you Mobile Customs. I'm looking forward to getting this installed this weekend, it's getting cold up here in Indiana. Now if I can just figure out how to hook up my heated drivers seat.....
Date Posted: December 21, 2006 at 7:34 PM
check out bypasskit.com they may have a module that does everything you need heat seats, defrost etc.
Date Posted: December 21, 2006 at 10:40 PM
Ok, one final question, page 12 of my installation manual says to refer to techtip 1041 for wiring information on the door lock harness (H4), but I can find nothing regarding this technical bulletin. am I crazy? I want to hook it up like my factory keyless, press unlock once, it unlocks the drivers door, press it again, it unlocks the rest. do I need diodes to prevent backfeed? What wires hook to what in my Avalanche?
