05 accord coupe door trigger, tach
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=87632
Printed Date: March 30, 2026 at 10:56 PM
Topic: 05 accord coupe door trigger, tach
Posted By: MikeHusain
Subject: 05 accord coupe door trigger, tach
Date Posted: December 22, 2006 at 9:29 AM
I was wondering if anybody knows where I can access the door trigger for this car. Wire schematic says behind fuse box, but it is pretty difficult to access it. Any easier way ? Also, where is the transmission tunnel for the tach? Thanks.....
Posted By: mikvot
Date Posted: December 22, 2006 at 4:26 PM
door should be 18ga. WHITE/ Black (-) at side of fuse box in Lt. Green connector, all doors tach 18ga. Yellow, Blue, Red, Brown at PCM in center console White connector
Posted By: profuse007
Date Posted: December 22, 2006 at 4:38 PM
if the above works, let me know.
i used to grab the triggers from the back of fuse panel. just a lil patience and youll get it. panel held by 3 10mm, i believe.
also, you can use dome light wire but it has a delay, located at driver a-pillar. on DEI units, you can turn off the notification chirp.
------------- Houston,TX
Posted By: mikvot
Date Posted: December 22, 2006 at 6:04 PM
yeah, i just did an 03 like 2 weeks ago, and that worked. both sets of notes i have say 05 is the same as 03...........i think that is only on lx and ex models only.now that i think of it, ive done prob 10 or 15 accords and never gone to the fusebox. oh well, give it a shot,hope it works.
