code alarm 425
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=87651
Printed Date: March 30, 2026 at 4:43 PM
Topic: code alarm 425
Posted By: mezzaricardo
Subject: code alarm 425
Date Posted: December 14, 2006 at 10:10 AM
Hello, everyone
I've installed the alarm brand name CODE ALARM 425, all the required connections are done (except the remote start cause it is not automatic car), so I'd like to know why the brain doesn't respond to the alarm controlls.
Everytime I place the fuses into the fuseholders, the siren starts to sound then, it stops but the alarm remains active.
Please, could somebody help me with some advise?
Ricardo Daniel Meza Cavazos
Posted By: mobilecustoms
Date Posted: December 14, 2006 at 11:23 AM
try to put in valet mode
or do the key over ride with the ignition on.
Date Posted: December 23, 2006 at 11:36 AM
Hello, I have a Ford Ka (brazilian car imported to Mexico), well...
I've installed a code alarm system.
the thing is, that I connected the green wire (neg) to the door trigger (driver's side) which works, but... when I open the passenger's side door with the driver's side closed the led of the alarm remains flashhing to activate itself again instead of remains inactive.
I know that I should isolate both door with a 1 amp diode, but can I isolate the trunk too?... by adding a door pin switch which also would need a neg. signal.
Or how many doors can I isolate ?... I mean, can I isolate 3 doors, maybe 5, from the same alarm wire of course (neg. or pos)... something like that?
Posted By: profuse007
Date Posted: December 23, 2006 at 12:23 PM
chck the link
Houston,TX
