Identify Remote for Car Starter?
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=87750
Printed Date: March 28, 2026 at 12:09 PM
Topic: Identify Remote for Car Starter?
Posted By: riverguy
Subject: Identify Remote for Car Starter?
Date Posted: December 25, 2006 at 2:36 AM
this is the information on my car starter
model ps-2600
canada 2678  122 309a
version 2.3-234
fcc  id   nah  800r
could someone tell me what brand name  this is  and what type of keyless remote i need to buy to operate it.
the starter  was on my 1999 dodge caravan when i bought it  but they was no remote for it.
riverguy canada
Posted By: kgerry
Date Posted: December 26, 2006 at 11:26 AM
sounds like a Polar Start 2600   made by Autostart
could also possibly be a Pro Start   also made by Autostart
Kevin Gerry
MECP First Class Installer
Owner/Installer
Classic Car Audio
since 1979
Posted By: roadworks
Date Posted: December 27, 2006 at 12:31 AM
What you have is a Polar Start.... The remote is a 2 button remote..  A remote from a Autostart AS1200 should work.. You can even check with Canadian Tire. Not sure what model would work. I  think the antennea on that model is just a regular coaxial plug. Where are you located in Canada?
Posted By: riverguy
Date Posted: January 04, 2007 at 7:54 PM
hello
just wanted to say thanks for the advise you gave me on the car starter ps 2600     i think iam out of luck to find a remote to run it. DO you think they would be another type of starter that has same type of plug in that mine already has it would save alot of time and money from getting it re-wired.
riverguy canada
Date Posted: January 04, 2007 at 9:28 PM
No .. Since that unit came out Autostart has redesigned the plugs.. If I'm not mistaken the colours should still be the same.. It would be just a matter of cutting off the old plug and soldering on the new one.. but remember to pull the fuses first.. and you will have to run the new antennea. I have installed quite a few of the CT3300 from Canadian Tire and have found them very good..  I can't remember if that particular Polar Start has the second ignition relay in the unit.. You might want to look for an extra relay under the dash.. according to the wiring, your vehicle requires 2 ignition wires.. the CT3300 has the extra relay onboard.
Posted By: Firemech
Date Posted: January 08, 2007 at 4:50 PM
I have a couple of remotes for this, Private message me for details.
