01 ford ranger remote start
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=87760
Printed Date: March 28, 2026 at 7:22 AM
Topic: 01 ford ranger remote start
Posted By: kade29
Subject: 01 ford ranger remote start
Date Posted: December 25, 2006 at 12:34 PM
I have an 01 ford ranger, I am trying to find a wire diagram to install a prostart CT - 3200 can anyone out there help me out ?
Posted By: another-kelly
Date Posted: December 25, 2006 at 12:55 PM
12volts yellow + ignition harness
Starter RED / lt. blue + ignition harness
Ignition lt. GREEN/ purple + ignition harness
Accessory gray / YELLOW + ignition harness
Second Accessory BLACK/ lt. green + ignition harness
Power Lock pink / YELLOW - driver door harness or PKP
Power Unlock pink/lt. green - driver door harness or PKP
Notes: The GEM in this vehicle shuts down after the doors have been locked for a certain time period, to wake-up the system refer to directfax document #1093.
Lock Motor pink/black driver door harness
Unlock Motor RED / orange driver door harness
Parking Lights+ brown headlight switch or GEM
Notes: The GEM (Generic Electronic Module) is to the left of the radio.
Door Trigger - GEM
Notes: The driver door trigger is yellow/black and the passenger door(s) is gray/red. Use both wires and diode isolate as shown in directfax document #1076.
Dome Supervision use door trigger
Tachometer tan / YELLOW instrument cluster or PCM
Notes: The PCM (Powertrain Control Module) is on the top of the firewall under the hood towards the passenger side. The tachometer wire is in pin 48. Can also get tach at the ignition coil or coil pack. Use any of the tan/stripe wires.
Brake Wire lt. green + brake pedal switch
Horn Trigger yellow/lt. green - steering column
Immobilizer Bypass Required: Yes
Type: SecuriLock
Part #: 1100F
Alternate Part1 #: 1100X
Alternate Part2 #: 556SW
Alternate Part3 #: 556UW
Alternate Part4 #: DesignTech 20402
Alternate Part5 #: DesignTech 29402
Notes: When using the 1100X, a software change to 1100FM is needed.
Posted By: dea,can
Date Posted: December 27, 2006 at 7:31 PM
on the back of the remote starter unit 12 digit number go prostart.org then go to downloads type in that number its a 1 time only so print off what u need .
------------- dragon
