02 Rav4 alarm
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=88000
Printed Date: May 16, 2026 at 1:50 AM
Topic: 02 Rav4 alarm
Posted By: x10kx
Subject: 02 Rav4 alarm
Date Posted: December 29, 2006 at 4:41 PM
Ive installed a Clifford Arrow5 into my gf car. everything works fine but i cant seem too get the parking light. Ive tapped the Wht/Red it into the harness which is GRN/RED nothing happen. Even try up at the hood. Would like too know if i connected the correct wire. Also I was wondering about the double pulse unlock. Is there something that I can do too use this feature got the single pulse too lock and unlock driver but would like double pulse too unlock all doors
Posted By: Chris Luongo
Date Posted: December 29, 2006 at 6:49 PM
Where did you get the GREEN/ red wire in the car? Did you TEST it? (Hopefully yes.)
You can also get parking lights at the dimmer switch. Green positive.
And exactly what are you wondering about double-pulse unlock? If the Clifford has that feature, just turn it on in programming, and then all the doors will unlock with one press of the remote.
Posted By: x10kx
Date Posted: December 29, 2006 at 7:09 PM
Hey Thnx alot for replying
Well I got the Grn/red wire just off too the right of the fuse box and i sure did tested.Came on when i turned on my parking lights and off but when i connected the alarm wire too it nothing happens.
Tried it at the dimmer switch also.
any other suggestions?
Posted By: KarTuneMan
Date Posted: December 30, 2006 at 10:26 AM
Is the parking light output POS(+), or NEG(-)....I know it's a silly question...BUT! Is it programable?
Date Posted: December 30, 2006 at 10:31 AM
You have the wrong parking light wire....the RED / white is the INPUT for the internal parking light relay. For POS(+) light flash, this wire needs to go to 12V. the parking light wireyou need from the H1 harness is one of the white ones....H1 # 13, or 14.
