difference between DEI 555H and 556H?
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=88083
Printed Date: April 19, 2026 at 7:02 AM
Topic: difference between DEI 555H and 556H?
Posted By: z28tt
Subject: difference between DEI 555H and 556H?
Date Posted: December 30, 2006 at 9:25 PM
I just installed the DEI (Hornet) 569T remote starter in my fiance's '01 Honda Accord LX (without factory alarm), and realized that it's got the immobilizer key (RS works with the key inside the ignition cylinder). Anyways, next step is to get an ignition key immobilizer bypass installed. What's the difference between the DEI 555H and the 556HW? Will both work? Is one plug and play, and the other is strip and solder? No big deal either way, bit a 10 minute job is nicer than 2 hours...
Andris
'89 Twin Turbo Camaro, T56, etc...
Posted By: captainzab
Date Posted: December 31, 2006 at 12:43 AM
both will requre for you to cut a wire in half and to tap into other wires.
555h deals with older hondas (98-02), 556h does everything 555h does plus newer years.
BTW, you can also search for bypasskit's PKH2
they are all the same when it comes to wiring, all require 1 key for programming.
pick whicher is cheaper.
Note: You Always Dont Get What You Pay For.
Posted By: z28tt
Date Posted: December 31, 2006 at 11:11 AM
Thanks. My local Tweeter has the 556H in stock for less than mail order + shipping, so that it is. Thanks again!
Andris
Posted By: profuse007
Date Posted: December 31, 2006 at 12:37 PM
check EBAY and search for PKH2
pkh2-22bucks shipped
IMO, i like it better than DEI 555H or 556H. very low profile.
Houston,TX
