05 buick lesabre, alarm/remote start
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=88124
Printed Date: April 19, 2026 at 1:26 AM
Topic: 05 buick lesabre, alarm/remote start
Posted By: steve700xedge
Subject: 05 buick lesabre, alarm/remote start
Date Posted: December 31, 2006 at 3:36 PM
I have installed a dozen or so remote starts but this is the first with a data wire for alarm bypass. I have done gm's passlock so is the passkey done the same way? I have found differant wiring info on this so could someone post the actual diagrams. I have bought a 555g and wiring diagram says I need to hook purple wire to data at the ignition but can't find diagram that tells which wire this is thanks steve
------------- 2003 silverado2500HD LT crew cab
Posted By: Ravendarat
Date Posted: December 31, 2006 at 3:46 PM
Hook up to the purple wire at pin two of the data conecter under the dash
------------- double-secret reverse-osmosis speaker-cone-induced high-level interference distortion, Its a killer
Date Posted: December 31, 2006 at 4:34 PM
thanks but exactly how do I do that, do I need some sort of connecter to plug in the front and how do I know exact location of that pin
Date Posted: December 31, 2006 at 4:37 PM
also what are the colors for the ignition wires to hook up to the pink/black and the pink wires of the 555g
Date Posted: January 01, 2007 at 10:49 AM
ok maybe i'll explain a little better, does anyone know the colors of the specific wires for the 555g pinkignition (ecm side)- pink/black(key side) to match up to at the key cylinder or how to find which one is which. I know these are thin gauge wires and I have done many passlock ll but this is the first passlock lll and I've always been able to find the ones I needed ina diagram but now I cant seem to find specific wires thanks for your time
Posted By: Chris Luongo
Date Posted: January 01, 2007 at 1:00 PM
Why mess around with the 555G?
Get a GM-DLBP from bypasskit.com, and it does locks, trunk, factory arm/disarm, as well as Passkey III bypass, all with one piece.
Date Posted: January 01, 2007 at 1:16 PM
yes but this is for my mothers car and my father bought her a standard starter without the unlock/lock so I purchased the 555g thinking this would be what I needed, he bought it thinking that I could install it because I was able to do so on her '96 regal but that was differant system with wires coming from key cylinder and this one has a black control type of box with 5 wires coming from it from left to right - purple,purple,black,pink, orange so which of these do I cut and which one do I splice into
Posted By: Velocity Motors
Date Posted: January 01, 2007 at 5:41 PM
I suggest getting a databus module for this vehicle so you don't have to grab the OEM alarm disarm wire in the door. Trying to get from the driver's door to the inside of the vehicle is an absolute pain.
------------- Jeff
Date Posted: January 01, 2007 at 8:27 PM
ok if I get agm-dcbp just exactly do you go about connecting to data ports( I mean do I need come sort of a special connector to plug in or just splice into the wire coming out of the port)
Posted By: another-kelly
Date Posted: January 01, 2007 at 8:58 PM
the purple wire at the obdII connector. just solder into the wire
Date Posted: January 02, 2007 at 4:37 PM
ok do I need the gm-dlbp to override the oem alarm and not go into the door or will a gmbp work seeing as I don't need the unlock/lock function
Date Posted: January 02, 2007 at 4:59 PM
Yes you will need the GM-DLBP to override the OEM alarm without going into the doors. Also, what kind of starter are you installing that doesn't have keyless capabilities ?
------------- Jeff
Date Posted: January 02, 2007 at 11:04 PM
auto command that my dad probably at target but all she wants is the ability to start her car in the unattached garage on the cold minnesota mornings
Date Posted: January 03, 2007 at 8:40 AM
If there is no option for (-) trigger door locks on the AutoCommand unit, then that feature on the module willnot be used. If it does have triggers you might as well have it hooked up.
------------- Jeff
