dei 528t?
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=88240
Printed Date: May 04, 2026 at 4:47 AM
Topic: dei 528t?
Posted By: sri19
Subject: dei 528t?
Date Posted: January 02, 2007 at 4:41 PM
hi guys new to this forum, was just wondering if i could use a dei 528t to turn a momentary postive output into a 15 second negative output?
Posted By: sri19
Date Posted: January 02, 2007 at 4:47 PM
i want to use it as a window closure module on a standard factory remote central door locking set up, so when the momentary positive output of the locked signal activates, it then swaps over to a negative output that will last for 15 seconds to lift the windows. The factory set up already has the input wire to lift the windows using the key turned in a 45 degree position, but no facility to do this from remote.
Posted By: swamprat323
Date Posted: January 03, 2007 at 12:07 AM
yes you coudl use that to do that but do you have igntion lock or when car go so fast that the door lock if so the windows will close
