remote start, car will not crank
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=88291
Printed Date: April 06, 2026 at 5:55 AM
Topic: remote start, car will not crank
Posted By: 98k1500chevy
Subject: remote start, car will not crank
Date Posted: January 03, 2007 at 4:05 PM
I have a 2002 monte carlo 3.8l and i am trying to put a remote starter in it and it is the 1400xp model from python. My problem is that the vehicle will start and run fine with the remote starter if the key is in the acc. position, on position, or run position, but if the key is off all of the relays click and the interior lights, gauges, and parking lights come on for a quick second then shut right off and the car does not crank. I have gone over all of my wires and connections and double checked them and i am at a loss, i have spent 14 hours on this, and really really really could use your help. Thank you.
Posted By: deviousjoker
Date Posted: January 03, 2007 at 4:26 PM
it could be 2 things. 1st did you bypass your passlock 2 system. 2nd you might be missing an ignition wire(green).
------------- First Class MECP Installer
Posted By: xtremej
14 hours wow. what did you use to bypass the passlock II?
Date Posted: January 03, 2007 at 4:34 PM
I used the bypass moduel 1700g, its the real simple one just power, ground, ground when armed, and data bus wire to pin 2 on obdII. i know that the by pass is working because i have been told the vehicles bypass is done during the crank cycle, and the car will start with the remote start if you just click the key to the accesory position, so it would be relying on the by pass to crank, which it does crank and start with the remote as long as the key is in accesory. Also, the green wire is powered.
Posted By: xtremej
Date Posted: January 03, 2007 at 4:50 PM
Have you verified with a meter that both ignitions are being powered when remote starting?
Posted By: rudydapimp
Date Posted: January 03, 2007 at 4:51 PM
i would still think that the bypass is not working. if the key has to be in ignition to remote start it, then its not recognizing the bypass
Posted By: xtremej
Date Posted: January 03, 2007 at 4:55 PM
Are you getting any security lights when attempting to remote start without the key in the ignition?
Date Posted: January 03, 2007 at 5:06 PM
no i have not checked that but will right now. No, i am not getting any security lights.
Date Posted: January 03, 2007 at 5:38 PM
hi guys, thanks for the idea to check all the voltages, ended up being a bad relay, for the second ignition, the part that was hard was that they are built in relays, so i wired up and external one, and its good to go, thanks again everyone.
Posted By: ugbandtulsa
Date Posted: January 03, 2007 at 11:37 PM
I used the bypass moduel 1700g, its the real simple one just power, ground, ground when armed, and data bus wire to pin 2 on obdII. Remember, it's ground when running, not armed. On DEI products, this will be blue/white on newer products, blue on most older products at the relay pack, and blue/black on some also. NOT orange. That's the starter kill wire. Check these, in this order: 1. With test light, check purple starter wire for output at crank, when you hear the relay pack click. 2. Check for 2nd and 3rd ignition, or 2nd accessory. Some cars will not crank without 2nd accessory power. 3. Use a 556L instead, I hate the 1700g. I have had several of these modules fail, and act inconisistently. 4. This is a relatively simple install, so if you check the above, it will start.
