Autopage 860, 94 dodge ram 2500
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=88323
Printed Date: April 07, 2026 at 12:59 AM
Topic: Autopage 860, 94 dodge ram 2500
Posted By: alienturdle
Subject: Autopage 860, 94 dodge ram 2500
Date Posted: January 03, 2007 at 10:32 PM
i bought an Autopage rs-860 lcd remote start alarm today and have been installing it all just fine untill i got to the 20 pin harness. in the manual it shows 1 being WHITE/ black 2 WHITE/ violet ect ect/ but when i look at the actuall connector none of these wires are in order. they are their but not in order? are they soposed to be? should i continue to install? thanks! let me know asap please
Posted By: lamikela1
Date Posted: January 04, 2007 at 11:33 AM
Go by the wire color not the pin position. You won't have any problems that way.
Date Posted: January 04, 2007 at 12:05 PM
woooot thanks!
Date Posted: January 04, 2007 at 2:09 PM
iv been trying to get my alarm installed and i cant get my remote start to work. im putting it in my 94 dodge ram 2500 and i got the diagram off of here for the wire colors. now i know i have the remote start wires right. 6pin H1 the 2 red with fuses to pink/black the violet to yellow the yellow to the dark blue (i hooked it to the thick blue wire) the pink dont use the brown to BLACK/ orange
the 20 pin harness i have WHITE/ black going to hood pin switch with diode blue going to hood pin switch with diode WHITE/ violet to WHITE/ tan on brake switch BLACK/ white wire i just have grounded green wire to the yellow wire at the door switch WHITE/ red wire to the grey/black wire for tach signal
i havent used any other wires and it still wont remote start i hit the button on the remote and it just beeps 3 times i tryed the tach signal programing but i get to the part of it where i start the vehicle and the head lights flash but they only flash like 2 times and nothing happens when i press and hold the valet switch for 2 seconds and long chirp. thats where im stuck
