Window roll up module, alarms, central loc
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=88333
Printed Date: May 16, 2026 at 11:40 AM
Topic: Window roll up module, alarms, central loc
Posted By: wog_boy
Subject: Window roll up module, alarms, central loc
Date Posted: January 04, 2007 at 3:55 AM
Hey all,
I was installing my new alarm i received today for Christmas in my Nissan Silvia s13, i came across a few complications with:
-the original central locking, connecting the actuators to the alarm and making them work do i need a relay or something of the similar to make it work????? i already tried to connect the 2 wires coming from the alarm to the actuators and all i got was blown fuses??? should i connect it to the Nissan door control module with a relay???
-secondly, the drivers side switch on the power windows does not work i was going to fix it when i installed the alarm and i don't know where to start any advice???? do nissans have 2 window box modules
- and thirdly, with the alarm i received a window wind up module so when i lock my car the windows go up at the same time i tried connecting this and it don't work again?????/
Any help would be greatly appreciated,
CHEERS.
Posted By: wog_boy
Date Posted: January 04, 2007 at 3:58 AM
all rite got more info, i got the links here to the alarm and the window module.
-https://cgi.ebay.com.au/NEW-REMOTE-ENGINE-START-CAR-ALARM-IMMOBILISER_W0QQitemZ140068914394QQihZ004QQcategoryZ31250QQrdZ1QQcmdZViewItem
-https://cgi.ebay.com.au/DEI-530T-POWER-WINDOW-ROLL-UP-MODULE-PYTHON- HORNET_W0QQitemZ280065788724QQihZ018QQcategoryZ31250QQssPageNameZWDVWQQrdZ1QQcmd
ZViewItem
info on the c/l brain:
*GREEN/ black wire- active at unlock neg at lock and rest
*Green-active at lock neg at unlock and rest
*black-neg
*Orange-Stays active on lock and ground at unlock
*WHITE/ red-Always active
and my alarm has a lock and unlock wire and 3 different ways of hooking it up: negative trigger positive trigger and positive/neg trigger.
I have looked at the relay page and still got no idea any help would be good
Hope this helps
Posted By: cpgoose
Date Posted: January 04, 2007 at 6:32 AM
Your links aren't working for me when I cut/paste them. Please check those.
