Ground when running?
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=88520
Printed Date: May 10, 2026 at 6:17 AM
Topic: Ground when running?
Posted By: bigfoot286
Subject: Ground when running?
Date Posted: January 07, 2007 at 11:14 AM
I am going to do a r/s on an 06 f-150 and i am using a 1100x , it says to attach to ground when running? what do they want there, is there a ground when running wire? or do they want ground when armed????
Posted By: xtremej
Date Posted: January 07, 2007 at 11:42 AM
ground when running, is what they want. It triggers the ignition bypass ie the 1100x.
Posted By: splaudio
Date Posted: January 07, 2007 at 4:55 PM
there is a wire ground when running in the harness with the small gauge wires on ur starter,dont know what brand ur using...
Posted By: Mike M2
Date Posted: January 07, 2007 at 5:31 PM
It may be called a statis wire on your RS...
Mike M2
Tech Manager
CS Dealer Services
