Wiring for backup camera
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=88528
Printed Date: May 10, 2026 at 2:29 AM
Topic: Wiring for backup camera
Posted By: baddogonadodge
Subject: Wiring for backup camera
Date Posted: January 07, 2007 at 1:51 PM
I have a VR3 VRBCS300 backup camera that I'm trying to hookup fo my 2005 Dodge Ram 1500 PU.  The instructions tell me to 1) connect the red power wire to the ACC power terminal in the vehicle's fuse box and 2) locate the vehcicle's back-up light circuit and splice into it.  This is all great, but where is my accessory terminal and how do I plug into it.  I can identify the fuses in the panel like those for the back-up lights, but all the wires coming out on underside of fuse box are just like plugging into a circuit board.  How can I find out what's what?
Posted By: Velocity Motors
Date Posted: January 07, 2007 at 2:01 PM
The RED wire would just go the a switched IGNITION power. For the RAM it will at the ignition switch ( PINK/GREEN ) or find a switched ignition fuse at the fuse panel and tie into it there.Use a DMM.
