2000 Dodge Dakota door locks
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=88576
Printed Date: May 10, 2026 at 12:20 AM
Topic: 2000 Dodge Dakota door locks
Posted By: habco1
Subject: 2000 Dodge Dakota door locks
Date Posted: January 08, 2007 at 10:43 AM
Does anyone have a schematic of the lock system in this truck. They have stopped working and all that happens is the relays click when the switch is pressed to either lock or unlock. I have positive when switch is in unlock and not when in lock. I have negative on lock side when switch in neutral position but not in unlock.
Posted By: Hymer
Date Posted: January 08, 2007 at 10:48 AM
factory keyless on the truck?
Tire Proz Stillwater Mn
High End Restyling and Comlete Repair
Posted By: habco1
Date Posted: January 08, 2007 at 11:37 AM
Yes it is. I am trying to see if there is a breaker that needs to be replaced oe reset maybe.
Posted By: Hymer
Date Posted: January 08, 2007 at 11:44 AM
could be, if you crack the door panel on it there should be 2 wires on the actuato and when the lock switch is pressed you should get 12v on one wire and a ground on the other, when you hit the unlock side of the switch the tow wires will reverse polarity if you dont get that at the actuator then back track to the switch and look for the 12v feed wire and the ground, if one of the two isn't there then its a bad breaker , relay, or a bad ground somewhere..
Posted By: habco1
Date Posted: January 08, 2007 at 11:52 AM
Do you know where I can get a schematic for this system showing where all the relays and breakers for it?
Posted By: Hymer
Date Posted: January 08, 2007 at 12:11 PM
I don't think you'll find a schemo for the truck,   but most dodges have the relay banks and such up in the engine bay. my dadtabases just give the interface wires and locations for security and rs.. when it comes to this kind of troubleshooting, most of the time your traceing wires. keep in mind dodges are notorious for "fuseable links" these are burried in the wire harnesses and a real PIA to find if you don't have a service manual. You could try going to a checker are a barns and nobel and looking for a chiltons manual, there schemos are kind of bad but it may point you in the right direction...
Posted By: habco1
Date Posted: January 08, 2007 at 12:24 PM
Thanks for the info.
