Autopage RS725LCD ground when running?
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=88739
Printed Date: May 14, 2026 at 4:33 PM
Topic: Autopage RS725LCD ground when running?
Posted By: taboolie
Subject: Autopage RS725LCD ground when running?
Date Posted: January 10, 2007 at 9:00 PM
Try to make a long question short. Which wire on the Autopage RS725LCD should I use as the "ground when running" to attach to the GM-SL bypass kit?
I believe I have it attached to the ignition 3, which allows the car to start I'm sure, but right after the theft light comes in, as well as the radio locks. Weird. When I put the key in the ignition and flip it to on, then hit the break to disengage the remote start, the headlights dim, almost to the point of being off, then in about 5 seconds, they come back up and the theft light turns off. As well does the radio.
Works yes, annoying as heck and could be connected to the proper wire, yes also.
Anyone know the proper wire I should be connecting the GM-SL to? I installed an RS620 which allows the pink wire to be programmed for ground out when running (if my memory is correct) but no such luck on the RS725.
Now I'm assuming this problem is because of this, if not, please by all means help!.
thanks guys!
Posted By: KarTuneMan
Date Posted: January 10, 2007 at 10:23 PM
You should make your question a tad bit longer.....whats the year make and model?
Posted By: taboolie
Date Posted: January 11, 2007 at 6:38 PM
Oh yea, just imagine if I wanted to make a long question eh :)
2002 Chev Impala
thanks
