Any way to hook up RS to open Garage Door
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=89000
Printed Date: May 06, 2026 at 3:12 AM
Topic: Any way to hook up RS to open Garage Door
Posted By: mbaudio06
Subject: Any way to hook up RS to open Garage Door
Date Posted: January 15, 2007 at 3:41 PM
If there is a way please recommend a certain RS with this option. Or maybe any RS with some sort of Aux output..
Posted By: Hymer
Date Posted: January 15, 2007 at 3:46 PM
You could crack your remote open for the door opener and run a aux output to pulse a relay to close the contacs on the switch in the opener. the remote would need to be permanantly in the vehicle... should be pretty simple....
Tire Proz Stillwater Mn
High End Restyling and Comlete Repair
Posted By: profuse007
Date Posted: January 15, 2007 at 5:23 PM
^thats prolly the cheapest way to do it. else, you can buy a module from clifford, audiovox, or DEI. check eeebayDOTcom
Houston,TX
