73 Duster, door locks, alarm
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=89026
Printed Date: May 05, 2026 at 9:39 PM
Topic: 73 Duster, door locks, alarm
Posted By: duster man
Subject: 73 Duster, door locks, alarm
Date Posted: January 15, 2007 at 10:02 PM
I have a 73 Duster that I am installing an alarm and power door locks on and I just can't seem to get them to work. So here is what's going on now.
Door locks: Key on - both door locks work, correct.
Key off - both door locks don't work, correct
Key on with the alarm hooked up - both locks
barely move.
Alarm: Key on - both door lock don't work, correct
Key off - both door locks barely move.
Key off with the drivers side door lock
disconnected - alarm button sets the alarm
and locks both doors.
I have two relays hooked up for the alarm and they seem to be working fine. I feel like power is getting back to the door switch when I set the alarm, but I don't know how the fix it. Thanks for any help you can provide.
Posted By: KarTuneMan
Date Posted: January 16, 2007 at 7:24 AM
where did you get 12v for the relays....AND, I believe that you might have one, or both of the relays wired incorrectly. When you say "key on"...what posistion, accs, or ign. ? What type of alarm? -------------
Posted By: Hymer
Date Posted: January 16, 2007 at 8:54 AM
follow the diagram for 5 wire rev door locks here, and wire them up to your alarm just as the diagram states. double sheck your 12v ign and accy wires off your alarm.
------------- Tire Proz Stillwater Mn
High End Restyling and Comlete Repair
