Smart Start Interlock Device?
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=89066
Printed Date: May 05, 2026 at 12:47 PM
Topic: Smart Start Interlock Device?
Posted By: GZus
Subject: Smart Start Interlock Device?
Date Posted: January 16, 2007 at 6:30 PM
I was wondering if anyone installs the smart start interlock units and if so what color is the  tach wire input if there is one. Thank you
G
Posted By: KarTuneMan
Date Posted: January 16, 2007 at 6:34 PM
You don't need a tach signal for these types of devices....
Posted By: GZus
Date Posted: January 16, 2007 at 6:43 PM
I would think you would need one so that the unit knows that the car is running, rather then going by a type of voltage sensing system that I think could not work 100%
G
Date Posted: January 16, 2007 at 6:53 PM
They work perfectly...."trust me"   I have installed them, and am currently "borrowing" one....wink, wink.
The first blow enables the car to start, triggering an internal electronic relay for the broken starter wire. The second blow (or 3rd,4th,and 5th) is recorded on the unit for download at a later date.
Posted By: GZus
Date Posted: January 16, 2007 at 7:07 PM
I have one and my alternator is not functioning perfectly but does work. And acouple of times when I started my car after I passed it didn't think I started the car and ask for another breath sample with out the 6 min time limit while driving.
G
Date Posted: January 16, 2007 at 10:36 PM
It's NOT a set pattern......You must do what it asks. If you feel it's malfunctioning....take to the folks that put it in....better than gettin in trouble...agreed?
Posted By: GZus
Date Posted: January 17, 2007 at 6:35 AM
agreed
G
