What kind of remote start?
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=89178
Printed Date: May 14, 2026 at 7:36 AM
Topic: What kind of remote start?
Posted By: iceman7329
Subject: What kind of remote start?
Date Posted: January 18, 2007 at 8:22 PM
Ive got a guy want a remote starter put on his 97 expedition (sp). He doesnt care what I use as long as he has remote start. Im almost thing about using a add on system that uses the factory remote. Would this be just as good as a DEI system? If this type of system works good what brand do you recommend?
Posted By: chris354
Date Posted: January 18, 2007 at 11:51 PM
I would just go with a complete syste. On this truck the factory keyless will not work while the truck is running unless you interupt the ign at the keyless entry unit while its running. You also just dont get alot of rangfe from factory key fobs. If your wanting something cheap I believe circuit sells the 561r for like $79. They only come with 1 remote but will do keyless and start and very reliable.
Date Posted: January 19, 2007 at 6:06 AM
That would probably be the easiest thing to do. I can get the 561r for like $50, never pay retail IMO.
