2006 hummer H3 remote start
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=89245
Printed Date: May 15, 2026 at 1:32 PM
Topic: 2006 hummer H3 remote start
Posted By: ela david
Subject: 2006 hummer H3 remote start
Date Posted: January 13, 2007 at 6:34 AM
I'm Ela and I found this site few days ago. Could you help me? I tryed to install an alarm (Magicar M9000 M902F) with starting engine from remote feature on a Hummer H3 made in 2006 but it doesn't work. I sis use the right value of resistors, the right relays, the WHITE/ yellow and the WHITE/ blue wires from the ingnition but it still not working. If you will give me an e-mail address I can attache and send you the wiring diagram that I've been followed.
Posted By: tdr-inc
Date Posted: January 13, 2007 at 7:16 AM
Ela, I think we would all need a little more information about what does not work and what does.  I believe this vehicle uses GM's new start sequence where accessory voltage must be applied first, then ignition, and then the accessory voltage must turn off... this will cause the starter to engage.  You may need to check your remote starter to be sure it can duplicate this sequence.  I don't think there is an actual start wire to hook up.  Along with the passlock II bypass you will need to trigger the key sense wire durning remote start. I am not sure of the color but the last GM I did it was green.  Hope this helps.
-Tim
Date Posted: January 20, 2007 at 3:23 AM
Could you help me wuth a diagram for by-pass the immobilizer? I install an alarm on a Hummer H3 from 2006 but I can't make the starting engine from reamote feature to work. Could you help me with an advice?
Posted By: KarTuneMan
Date Posted: January 20, 2007 at 9:46 AM
I have never done an H3....it says passlock 2  A good bypass would be a Passlock SL2 H3
Someone thats done one might have a better answer though!!!!
Posted By: xtremej
Date Posted: January 20, 2007 at 12:59 PM
Try this diagram it works well. I have done 3 h3/s this way with no problems.
Date Posted: January 29, 2007 at 2:35 AM
Tim, thank you for your advise. I will send you by mail the wiring diagram that I've been used. Under the wheel I found 5 wires: white with orange, white with green, white with black, white with blue and white with red. I will send you by mail the wiring diagram for immobilizer and how I found the resistor value adn how many releys I used.
Ela
Date Posted: January 29, 2007 at 2:37 AM
Tim, can you send your e-mail address to ela.golubov@solidpoint.ro? Many thanks
Posted By: jcato
Date Posted: January 29, 2007 at 11:53 AM
ther is a new passlock bypass made specificly for the hummer h3. here is a link.
https://www.autotoys.com/x/cust/product.php?productid=9519
john
Date Posted: January 30, 2007 at 2:02 AM
Thank you John. I acces that site but I can't obtain a diagram. I have the alarm I made a immobilizer from releys and resistors, but I thank I'm using the wrong wires from the car. I saw that is a difference between a Hummer H3 from 2005 and a Hummer H3 from 2006 (in Europe). Ela
Date Posted: January 30, 2007 at 2:07 AM
Thank you. Did you tryed on a Hummer H3 from 2006?. Couse I saw there are differences between H3 from 2005 and H3 from 2006.
Posted By: jcato
Date Posted: January 30, 2007 at 5:53 PM
i just recently bought the 2007 h3 and all the research ive been doing keeps showing that bypass. dont know about the 06 models. that link i posted is the only place on the net i could find it at since it was just released the middle of dec 06, i would think in another month or two they will be all over the net.
john
Date Posted: February 09, 2007 at 1:20 AM
John, I can't affort to wait for 1 or 2 months for making the starting engine from remote.  I have to do it next week. I 've followed your advice but it doesn't work. Did you tryed to install an alarm with strating engine on your car?
