1992 honda civic hatchback remote start?
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=89295
Printed Date: May 16, 2026 at 2:39 AM
Topic: 1992 honda civic hatchback remote start?
Posted By: ///m3-racer///
Subject: 1992 honda civic hatchback remote start?
Date Posted: January 21, 2007 at 3:07 AM
Hey ppl im new to the whole alarm system/starter thing.
I have hooked many car audio items like amps/speakers/Xovers/headunits.So i took the chance to hook up my Nu start remote start & security. I conected all the wires in the CN1 section like 1+12v constant,2prkingLight,3+12v constant,Prewired Relay for 2nd   lg,Accor starter,4Accessory,5Starter kill/Anti-Gring.6Starter.7 Ignition. 8Ground. And then with the CN2 like the 1.(-) Light output 250ma,2(-)status outpout250ma,3(-) ignition 250ma,4 (-)Accessory output 250ma 4,(-) starter output 250ma,
Ok so i basicaly just wired it all up with the CN1 section But the status one i wired it up to my clutch switch on the black cable anyhow so i wired up all my doors/hood/ trunk everything so i program my remote and press the starter buttom and everythings seems rite like it blink 3 times waits a second then goes in the the Accessorys mode like with the key outa the ignition and nothing happens so then the alarm trys 3 more times and nothing starts. There is 2 relays on the system i wired them up rite i hope but is it cuz my car is manual tranny do i need somthing like a bypass ? the sales guys said i didnt i have the [CM3000] model its a compu star knock off i think they call it the Nuas 4000 i paid $225Cad for it on boxing day from Visions then i come back to get it installed and they qoute me $250 for install when the guy on the day of the sale said its gonna be simple install $60, hence i did it my self everything works fine but can t realy get it to start like it goes into the acc mode about to start and just dead silents anyone have some hints for me or clues. thanks
I love bass
Posted By: desh187
Date Posted: January 23, 2007 at 11:52 AM
First of all i would double check all the wires if they are hooked up correctly(see vehicle wiring on this section)and if you are absolutely sure that everything is hooked up right,then you have a problem with the control module.
Posted By: dre187
Date Posted: January 23, 2007 at 9:41 PM
you never mentioned hooking up the handbrake wire which you normally have to do on a manual install. you didn't mention bypassing the clutch either which needs to be done. assuming you do have everything hooked up right, all manual starter units require you to do a sequence to get the system into a ready mode. it's a safety feature to make sure the e-brake is up and -hopefully- the car is in neutral. since every company has a slightly different sequence, i can't tell you what yours is because i never installed "Nu Start". It is generally someting like...1- press the foot brake 2-engage the e-brake  3-press the start button on the remote...then the car stays running while you take out the key and get out and will shut off when you press the lock button.
Date Posted: January 24, 2007 at 6:08 AM
  Thank ppl for the help i figerd it out it was the status cable i pluged it into the negative on the clutch switch it was positive well it works great and i love it thanks again.
I love bass
