acura rsx horn trigger
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=89381
Printed Date: March 16, 2026 at 9:33 PM
Topic: acura rsx horn trigger
Posted By: ihkili18
Subject: acura rsx horn trigger
Date Posted: January 22, 2007 at 4:22 PM
Hey everyone I know the orange wire in the rsx at the horn switch is negative and requires no relay. On the directechs it says you can also go to a green wire at the security control unit for the horn but it does not say anything more. Is this green wire negative and is it just driving a factory relay so I dont need to make a relay? thanks
Posted By: Hymer
Date Posted: January 22, 2007 at 5:15 PM
Green (-) pin B2 connector B alarm module for 05/06
or Orange fuse box connector J (-)
Tire Proz Stillwater Mn
High End Restyling and Comlete Repair
Posted By: ihkili18
Date Posted: January 24, 2007 at 12:59 PM
hey hymer, can you clarify where the green wire is. Where is the b alarm module? i am also assuming the orange is somewhere close to the fusebox. can you tell me the exact?
Posted By: KarTuneMan
Date Posted: January 24, 2007 at 1:40 PM
On the fuse box ( drop it down) second row first connector on the left, next to a blue one. Which happens to be the tach wire. Horn is orange
Posted By: ihkili18
Date Posted: January 24, 2007 at 2:25 PM
thanks
