window roll up with aux output
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=89415
Printed Date: March 16, 2026 at 6:17 AM
Topic: window roll up with aux output
Posted By: schippka
Subject: window roll up with aux output
Date Posted: January 23, 2007 at 9:34 AM
<>I have a CT3400TW two way remote starter.
One option for the aux output is window roll up. Can I wire this directly to my power windows or do I need a module?
If I can wire directly. How? I think I would need a relay.
The aux output is a 500mA negative output. The manual says it can be programmed to stay on as long as the button is pressed.
I have a 98' ford windstar.
Posted By: killer sonata
Date Posted: January 23, 2007 at 9:36 AM
do you not have the manual that came with the alarm?
Posted By: schippka
Date Posted: January 23, 2007 at 11:33 AM
I do have the manual.
I want to know how to connect it to wiring so I can roll up the windows.
The manual doesn't have that info.
Posted By: swamprat323
Date Posted: January 23, 2007 at 12:35 PM
get a moudule is your best bet
Posted By: mikvot
Date Posted: January 23, 2007 at 5:13 PM
It can be done with relays, but as swamprat said, its best to use the module. You would need 1 relay per each window that you are trying to roll up. Not to mention the relay setup will not offer as much protection to the window motors as the module would. If the aux output on your alarm only offers a quick pulse, it would not work with the relays anyways. A module will let you send a short input pulse and would take care of the rest.
Posted By: mikvot
Date Posted: January 23, 2007 at 5:17 PM
sorry, didnt notice this........"The manual says it can be programmed to stay on as long as the button is pressed." I would still use a module. Hell, while your in there, i would through a module in for window down also.
