Ford Fiesta 03 Keyless Entry
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=89516
Printed Date: March 16, 2026 at 12:32 PM
Topic: Ford Fiesta 03 Keyless Entry
Posted By: dons_tdci
Subject: Ford Fiesta 03 Keyless Entry
Date Posted: January 25, 2007 at 3:42 AM
hi there im new to this
im based in the uk andi have a 2003 Ford Fiesta. it came with central locking(when a door is locked the other door locks and vice versa) and i bought an aftermarket kit from Ebay. it has a wiring diagram but im unsure of where to mount the module either inside the car or in the driver door. also i am unsure of what wires to tap into and where to tap into as i did attempt this before by using the loom in the drivers door. i think i identified the lock and unlock wires but when it came to testing by dding the module it didnt work.the module opens and there is a small button on the pcb which supposedly is the learning button and im unsure of how to teach the module what to do.
help would be great thanks
Donald-Alexander
Posted By: KarTuneMan
Date Posted: January 25, 2007 at 10:05 AM
 LOCK BLACK/ orange DKP harness from door   -
 UNLOCK BLACK / YELLOW DKP harness from door   -
You might also need to pulse the blk/grn in the same location to wake up the BCM, if the unlock wire listed above does NOT work. The blk/grn is also a NEG(-) pulse. Down LOW in the drivers kick is the esiest place to find the iwres.
Date Posted: January 25, 2007 at 12:47 PM
where did you get that information from? would be handy in the future when its warmer as i may attempt it then.
donald_alexander88@hotmail.com
