what if i mounted the antenna on the rear
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=89597
Printed Date: May 17, 2026 at 1:33 AM
Topic: what if i mounted the antenna on the rear
Posted By: peterubers
Subject: what if i mounted the antenna on the rear
Date Posted: January 26, 2007 at 4:07 PM
If I mount the antenna of the R/S on the rear window, will the defroster grid interfere w/ the RF?  Will The car have approximately the same remote start range?
The search function is your friend.
Posted By: Hymer
Date Posted: January 26, 2007 at 4:10 PM
Probably not a great idea. Most rear windows have some sort of tint and the defroster grid on them, The other issue would be antenna cable length...
Tire Proz Stillwater Mn
High End Restyling and Comlete Repair
Posted By: splaudio
Date Posted: January 26, 2007 at 4:50 PM
there would be no problem as long as u stick to a spot where there is no defroster lines.  the bad part is u would have to run some long wires from the module in the rear to the front ignition wires. i wouldnt recomend tapping into the antenna cable or running them under the carpet or sill plates because they are fragile...
