confused!
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=896
Printed Date: March 29, 2026 at 10:42 AM
Topic: confused!
Posted By: chou5521
Subject: confused!
Date Posted: May 22, 2002 at 8:08 PM
can anyone explained to me what  "The 12volt " alarm wiring information for a 2000 Dodge Ram P/U means;
Starter----Yellow----Must add Relay for Remote Start
Does that mean besides the starter interrupt relay and if it does can anyone help me how to hook up the relay? Alarm remote start and does have the output for the starter, if this helps.
Thanks,
Sal
Posted By: Velocity Motors
Date Posted: May 23, 2002 at 10:40 AM
Dodge
Ram Pickup
1999-2001
Remote Starter  Wiring Colors and Notes
Function
Vehicle  Color
Location
Start:
BLUE / YELLOW
IGNITION SWITCH HARNESS *
Ignition  #1:
D BLUE
Ignition #2:
BLACK/ ORANGE
IGNITION SWITCH HARNESS (HEAT/AC)
Ignition  #3:
N/A
Accessory:
BLACK/ WHITE
Brake  Light:
WHITE/ TAN (+)
AT SWITCH ABOVE BRAKE PEDAL
Tach  Signal:
GRAY/L BLUE
AT POWERTRAIN CONTROL MODULE **
Parking Lights:
BLACK / YELLOW (+)
AT HEADLIGHT SWITCH ****
Headlights:
LT. GREEN (+)
AT HEADLIGHT SWITCH
OEM Alarm  Disarm:
LT. GREEN/ ORANGE (-)
24 PIN CONN. BEHIND DRIVER'S DASH *****
OEM Alarm  Arm:
Diesel  Glow Plug:
ORANGE / BLACK
IN LARGE CONN. UNDER LEFT SIDE DR. DASH
Clutch  Bypass Wire:
Notes:
 * 2000 Vehicles may be equipped with a transponder immobilizer system. ** Powertrain Control Module Located On Passenger Rear Of Engine On Firewall.
Dodge
Ram Pickup
1999-2001
Alarm and Keyless  Entry Wiring Colors and Notes
Function
Vehicle  Color
Location
Constant  +12 Volts:
PINK/BLACK & RED
Starter  Kill:
BLUE / YELLOW
Ignition  +12 Volts:
D BLUE
Dome  Lights/Superv:
YELLOW (-)
OEM Horn:
BLACK/ RED (-)
STEERING COLUMN HARNESS
Power  Lock:
ORANGE / VIOLET
BLACK 8 PIN CONNECTOR
Power  Unlock:
PINK/VIOLET
IN DRIVER'S KICK PANEL ***
Trunk  Release:
N/A
Alarm  Input Wire:
YELLOW (-)
Notes:
** YELLOW (-) Wire Also Located In 8 Pin Black Connector Above Passenger Kick Panel. *** Reverse Polarity For Unlock.  - Positive Polarity Diagram For Lock. **** This Wire Can Be Found At a 84 Pin Black Connector Next To Steering Column. ****** A Ground Pulse Through A 1,565 Ohm Resistor Will Disarm The Factory Alarm. A Ground Pulse Through A 644 Ohm Resistor Will Arm The Factory Alarm.
This is what I have for the 2000 RAM PU. There are other variations of wire color codes for certain wires so please test all connections before connecting power .
Posted By: install_tech
Date Posted: May 23, 2002 at 1:46 PM
Use the nomaly closed diagram here: https://www.the12volt.com/relays/page2.asp#sk1 .
Connect the starter output from your unit to pin# 30 to bypass the starter interupt circuit. This will allow the vehicle to start with the remote start unit but not with the key in ignition.
Hope this helps.
install_tech
