04 impala security light
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=89643
Printed Date: May 16, 2026 at 5:01 AM
Topic: 04 impala security light
Posted By: luvs2div
Subject: 04 impala security light
Date Posted: January 27, 2007 at 4:13 PM
Installed a MARS 22 on over a dozen Impalas.  One in question starts fine,  runs fine, but the security light comes on every once in a while.  Then after a while it goes off.  Use PLJX on all of them.  This ones giving me fits.
Anyone else heard of this one?  It looks like it's wired correct.  I've done this for 8 years and 700 units.  Never saw this before.
Posted By: Velocity Motors
Date Posted: January 27, 2007 at 4:46 PM
Where did you grab your parking lights source from ?
Posted By: luvs2div
Date Posted: January 29, 2007 at 4:44 PM
It (Mars 22) has a positive or negative selectable output.  I put it over to negative and put a resistor in line with it.  It's worked well in the past.
Posted By: luvs2div
Date Posted: January 29, 2007 at 4:55 PM
OOPS...  My bad.  I  hooked directly to the BCM with a negative output from the MARS22.
Date Posted: January 29, 2007 at 10:02 PM
posted_image
Posted By: Chris Luongo
Date Posted: January 30, 2007 at 3:54 PM
At the parking light switch there's light blue negative, or BROWN / white positive; your choice. Either of those wires won't trip the check engine light.
