6 pin starter harness wiring
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=89719
Printed Date: May 17, 2026 at 12:02 AM
Topic: 6 pin starter harness wiring
Posted By: grey caprice
Subject: 6 pin starter harness wiring
Date Posted: January 28, 2007 at 10:55 PM
Im used to having one 12v constant power but this one has two and from the phrasing I think is has 3?this is exactly what it says
BROWN WIRE : second ignition Output (+). the brown wire provides +12v for a second ignition wire. This wire may instead be programed for use as a second accessory or second starter wire
what does this mean because there are other wires one already goes to the ignition on/run position, and one for the accessory position, and one going to the vehicle' starting wire. I have a 1994 chevy caprice.
Posted By: 05gt
Date Posted: January 28, 2007 at 11:00 PM
if your car has a second ignition wire or an accessory wire that is what you can use
Posted By: captainzab
Date Posted: January 28, 2007 at 11:45 PM
Your Chevy Caprice does not have another ignition or accessory wire.
Cut the brown wire and tape it.
Note: You Always Dont Get What You Pay For.
