’05 pathfinder, xk07 immobilizer interface
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=89949
Printed Date: May 14, 2026 at 4:08 PM
Topic: ’05 pathfinder, xk07 immobilizer interface
Posted By: mxxmikexx
Subject: ’05 pathfinder, xk07 immobilizer interface
Date Posted: February 02, 2007 at 6:01 PM
has anyone used the flashlogic/transponder bypass XK07 transponder interface for a 2005 pathfinder? their website lists the pathfinder but they dont have refrence wire colors for can hi/lo, or security LED on the chart, i know i can call tech. on monday to find out for sure, just wondering if anyone on here has used it?
https://www.bypasskit.com/Manuals/XK07_PKN3%20D11_I_EN.PDF
Mike Battaglia
Specialized Car Audio
Bensenville IL 60106
Posted By: cutter1122
Date Posted: February 07, 2007 at 8:23 PM
CAN Bus HIBlueBody Control Module
Data signal
posted_image
 COMMENTS: BCM is located on the right side of steering column. Wire is at pin # 6.
CAN Bus LOWPinkBody Control Module
Data signal
posted_image
 COMMENTS: BCM is located on the right side of steering column. Wire is at pin # 14.
