is keysense required on a 04 rsx
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=89957
Printed Date: May 14, 2026 at 12:02 PM
Topic: is keysense required on a 04 rsx
Posted By: csnut18
Subject: is keysense required on a 04 rsx
Date Posted: February 02, 2007 at 8:55 PM
Hi everybody, just wondering if keysense is required on a 04 rsx. I am installing a new compustar pro on this car. I was thinking that wiring up the factory disarm and arm should be enough. Am I correct. Thank you
Posted By: KarTuneMan
Date Posted: February 02, 2007 at 9:42 PM
| LOCK | WHITE/ blue/2 silver dots | On 16-pin BLUE plug above driver's kick | - | | UNLOCK | WHITE/ GREEN/ 2 silver dots | On 16-pin BLUE plug above driver's kick | - |
| FACTORY ARM | WHITE/ RED / 2 silver dots | On 16-pin BLUE plug above driver's kick | - | | | | These wires can also be found on the 20-pin plug at the factory alarm. See the photo. |
| | FACTORY DISARM | WHITE/ 2 silver dots | On 16-pin BLUE plug above driver's kick | - | | | | These wires can also be found on the 20-pin plug at the factory alarm. See the photo. |
Posted By: JWorm
Date Posted: February 02, 2007 at 9:59 PM
Key sense is not needed.
Posted By: csnut18
Date Posted: February 02, 2007 at 10:11 PM
Thanks for the responses. Now a similiar question, would sending a pulse to the keysense disarm the factory alarm? I think it does cause putting the key in the ignition without turning it seems to disarm the factory alarm. so correct me if I am wrong.
Posted By: JWorm
Date Posted: February 02, 2007 at 11:03 PM
I don't think it would, but I can test it tomorrow on my RSX and let you know then.
Why wouldn't you just connect to the arm and disarm wires listed above?
Posted By: csnut18
Date Posted: February 02, 2007 at 11:21 PM
I will do that but I wanted to know if in general if doing the keysense would disarm the factory system. The reason i am asking is in some cars like the new accords the factory disarm requires going into the door so to save time i was wondering if the keysense would do it. i think it does cause in the accords putting the key in disarms everything
