commando ez2500
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=89958
Printed Date: May 14, 2026 at 10:10 AM
Topic: commando ez2500
Posted By: msgtwl
Subject: commando ez2500
Date Posted: February 02, 2007 at 9:02 PM
I'm installing a EZ2500 and power door locks on my  1999 S-10. I can't seem to program the remote start function. Also, I installed power door locks too. Can I hookthem up to the EZ200 or do I use the module that came with the power lock kit? Any help would be greatly appriciated.
Posted By: KarTuneMan
Date Posted: February 02, 2007 at 9:49 PM
I / we, might need a bit more info on your remote start. can you post a diagram of it? Any web site I found with product info had no install diagrams!
Posted By: msgtwl
Date Posted: February 04, 2007 at 6:12 PM
Sorry it took a while to respond. I found a place online where you can download the install manual. Ther is a link on the right side. I went through the programming again last night and can program the alarm side, but not the remote start part 1. I also installed the power door lock kit if anyone knows how I hook it up with the EZ 2500.
https://www.commandoalarms.com/itm100014.htm
Date Posted: February 04, 2007 at 10:13 PM
For your door locks, wire up 2 relays for posative output via negative trigger
posted_image
What bypass did you use.    The H5-2 is the ground while running output. The manual is written ALMOST as confusing for a rookie, as the DEI...(status output) what rookie knows what that is......anyhow. Your truck is equiped with passlock 2 The ground while running "triggers" the bypass for ya.
What problem EXACTLY are you haveing with the remote start?
Date Posted: February 04, 2007 at 10:16 PM
I have NO IDEA what happened to the pictures
go here to see it https://www.the12volt.com/doorlocks/page3.asp#3wp
Posted By: msgtwl
Date Posted: February 06, 2007 at 8:17 AM
I am using a BYPASSKIT(www.bypasskit.com), part # GMBP, for Passkey2 & 3. I think I will try connecting the brown wire from the bypass to the H5-2 wire you mentioned. When I get to Start Feature1 programming I turn the ignition switch on and off 3 times leaving it off, push the valet switch 6 times and nothing happens. I will try it again after making the change with the H5-2 wire. After we get this figured out I may have a question for you regarding the power lock kit.
Posted By: msgtwl
Date Posted: February 11, 2007 at 11:14 AM
After a lot of research I found that I was using the pre 2004 manual and needed the after 2004. The programing is differant. Now it starts but shuts off right away. Sounds like the bypass. Any ideas.
