06 and 07 accord rs bypasses
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=90013
Printed Date: May 14, 2026 at 2:18 AM
Topic: 06 and 07 accord rs bypasses
Posted By: rudydapimp
Subject: 06 and 07 accord rs bypasses
Date Posted: February 03, 2007 at 9:14 PM
Hey folks, going to be installing a RS in both an 06 and an 07 accord this week, and neither wants to lose a key due to the 556UW. been looking around on here, and have seen a few different ones mentioned.
My choices,
1100F programmed to 1100H.
or
XK01.
ive never worked with either one, is one easier and better???
thanks in advance!!
Posted By: captainzab
Date Posted: February 03, 2007 at 9:32 PM
XK01 does doorlock only.
Get the PKH3 which bypass transponder.
Note: You Always Dont Get What You Pay For.
Posted By: saskpuller
Date Posted: February 03, 2007 at 9:46 PM
I did an Accord this past week and used the XK01 (HODL4) for the doorlocks etc and used  OM-Honda for  the transponder. I was going to use an XK05 for the transponder but we had an OM-honda around and it was cheaper. There aren't many vehicles out there that absolutely require a key loss.
Date Posted: February 03, 2007 at 10:34 PM
where can I buy the PHK3?? tried ebay but no luck. any ideas??? I need two of them, rough estimate on cost????
Date Posted: February 04, 2007 at 10:05 AM
does the Pkh3 also do arm and disarm?? i know that some units do.
Posted By: JWorm
Date Posted: February 04, 2007 at 10:53 AM
The cheapest solution is to find a PKH3 for the transponder key, and the HODL2 for the doorlocks, arm/disarm, hood pin, and door trigger.
Google should return some search results.
