universal starter switch with keys
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=90095
Printed Date: May 16, 2026 at 5:41 AM
Topic: universal starter switch with keys
Posted By: joba356
Subject: universal starter switch with keys
Date Posted: February 05, 2007 at 1:24 PM
I want to eliminate my ignition like "technoweenie" did in the gallery forums. I noticed he has another starter switch for if the alarm button is lost thats what i want. I want to have no ignition instead a hidden universal starter switch. So what im thinking of doing is taking the wires of the ignition running them hidden to where i want the switch and wiring it up there. Now here goes the question. I have noticed that on the wire diagrams For my 1992 Honda Accord it states two ignition cables one is (BLK/YEL) and the other is (WHT/BLK) now the switch i have has the following connectors on the back: the middle= STARTER, The right = IGNITION, and the left = ACCESSORY. Do i connect both the ignition cables together to the one location on the back of the switch? Do i need a relay?Explanations would be good. Can i use a four button accesory device as a remote start for my car?
The Universal Starter Switch With Keys i have: Max Amperage = 15A
posted_image
Posted By: joba356
Date Posted: February 05, 2007 at 1:26 PM
posted_image
Posted By: 410440
Date Posted: February 05, 2007 at 10:21 PM
If you were to read what you just wrote, would you understand it?
Probably not, thats also why no one has replied to your thread, now, if you were to re-type that and spell check, so that it makes sense, you might get a few more replies.
Thanks.
Matthew Robertson
Senior Installer
Best Buy Deerfoot Meadows
Calgary, AB, Canada
Posted By: joba356
Date Posted: February 06, 2007 at 6:42 AM
Thanks.
Sorry about that, but thanks for the suggestion.  I found more info on what i want so will try to explain better. I want to have that Universal Starter Switch to turn on my car. The back of the switch has the following outputs: Middle= Starter, Bottom= Battery, Left= Accessory, and Right= Ignition. I have a 1992 Honda Accord and it has two ignition cables one is BLACK / YELLOW and the other is just Yellow. Since the switch only has one Ignition output on the back i need to wire the second Ignition cable (From CAR) through a relay. How would i do that? Because i need to have both Ignition cables connected. Hope you understand. Thanks
Posted By: joba356
Date Posted: February 06, 2007 at 7:31 AM
"Update"
I think i found my answer. This site states that there are two ignition cables, but i found this site that states only one ignition cable not 2.
The Site: Ignition one only= BLACK / YELLOW
https://www.directwholesale.net/diagrams/diagram.asp?ModelID=12644&MakeID=3&link=BULLDOG
This site: Show's Ignition 1= BLACK / YELLOW, Ignition 2= BLACK/ WHITE
https://www.the12volt.com/installbay/detail.asp?info=alarm&year=1990-93&make=Honda&model=Accord&ID=1032&type=Alarm
