2006 audi a4 alarm, remote start wiring
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=90100
Printed Date: May 16, 2026 at 6:38 AM
Topic: 2006 audi a4 alarm, remote start wiring
Posted By: datatechent
Subject: 2006 audi a4 alarm, remote start wiring
Date Posted: February 05, 2007 at 2:38 PM
anyone have the 2006 a4 wiring diagrams for remote start \ alarm functions ?
any tips on installing on audi's ?
thanks
Posted By: KarTuneMan
Date Posted: February 05, 2007 at 10:31 PM
PASSIVE ANTI-THEFT YES TRANSPONDER   SEE NOTES
 12 VOLTS Red In harness from ignition switch   +
 IGNITION Black In harness from ignition switch   +
 IGNITION 2 Red (small gauge) In harness from ignition switch   +
 ACCESSORY Yellow/black In harness from ignition switch   +
 STARTER RED / black In harness from ignition switch   +
 STARTER 2 Blue In harness from ignition switch   +
 KEY SENSE Gray / YELLOW Ignition switch harness   +
 TACH SIGNAL Gray/w. stripe At any of the coils on the engine   AC
 FUEL INJECTOR Opposite of RED / blue On top of engine under cover   AC
 LOCK Blue/white At module inside driver's door   -
 UNLOCK Violet/gray (double pulse) At module inside driver's door   -
 DOORPIN BROWN / white On 12-pin black plug at factory alarm module   -
 This wire does not go completely to 12 volts when all doors are closed. This may cause falsing with some after0-market alarm system. A 1-k resistor between this wire and 12 Volts will solve the problem. See the appropriate diagram for more details. The factory alarm system is located below the carpet in front of the driver's seat in a black plastic box.
 HOODPIN BROWN / violet On red plug at factory alarm module   -
 TRUNK PIN Violet On 12-pin black plug at factory alarm module   -
 TRUNK RELEASE Yellow/red On 12-pin black plug at factory alarm module   +
 The factory alarm system is located below the carpet in front of the driver's seat in a black plastic box. You can also use a Violet / YELLOW inside the driver's door at the switch.
 FACTORY ARM Arms with lock wire
 FACTORY DISARM Disarms with unlock wire
 BRAKESWITCH RED / black At switch above brake pedal   +
 PARKLIGHTS SEE NOTES
 The parking lights require some special wiring to activate. See the provided diagram for instructions.
 HAND BRAKE BROWN / white On Green plun in Driver's kickpanel or at switch   -
 CLUTCH SWITCH Gray/black At switch above clutch pedal   Type 2
 VSS WIRE BROWN / red or WHITE/ blue Behind instrument cluster   AC
